Vray Light Visible in Reflections
Hi
I’m trying to make the Vray lights invisible in reflections. If Specular is turned off in the light properties, it’s sorted but this also removes the light affecting the specular reflection of other materials which is important to keep. If there is a way to fix this it would be appreciated to know.
N
I suspect turning off “Affect Reflections” in Update 3.1 will do exactly what you want.
That’s worked perfectly Peter, thanks!
