Vray lightmat problem
Hi the opacity slot in vray light material is not working with cuda.
Take a look here - VrayLightMtl will not render with alpha sequence - Issues - Chaos Forum
Thanx I put the vray light mat and a transparent vray mat in a blend mat instead.
I thougt the self illumination slot did not give the same result as vray light mat?
That is not a very good idea if not necessary. Blend materials are heavier to render and can increase render times.
If you don’t need the fancy options in the VRayLightMtl, it should be relatively the same.
Im using the displacement. I’ll try the fasterr solution then…
