Vray Lights at SOP-Level
I don’t know if this is technically possible but I wish we could have real primary-bounce VrayLigts with all the bells and whistles at the SOP level. For axample, we have some SOP-HDAs where we allways have to attach an area light with directionality to it. It would be such a quality of life improvement if the light was already part of the HDA.
You could use the @instance attribute with the object level path of the lights to place them over template points generated at the SOP level. You could also place preview geometry over those points - the @instance attribute will override the geometry over the template points that you’re using for preview.
I’m not exactly clear on the end goal so I’m just sharing thoughts here.
Best regards!
