If you switch from Irradience map to brute force as main GI engine, and you have “store with irradience map” on your vray lights, the lights does not show in the first gi pass…
Its not a bug i guess, but it would be nice if when you change to brute force, it would override this option in the vray light..
Use my script (vraylightMonkey) to mass turn them off.
It’s not THAT easy as just switching them back to direct mode, as when they are embedded in the IRMap you’ll want the subdivs to be MUCH higher than normal (64-128 or thereabout) which would be overkill in direct mode.
Me, i’d rather they stayed as they are now, thanks
Maybe I’m missing something but, the intensity you get in bruteforce with ‘store with irradiance map’ checked is incorrect, while if you ignore the check box in bruteforce the lights produce the same intensity in all cases, behaving in a more predictable way, which IMHO is the desirable way.
If you have the lights subdivs very high, you still can use VrayLight Monkey to change them
hmm. that explains alot.. I think this info should be included in the help files, I was thinking that the hsp subdivs overrided the samples in the vraylight..
Actually I have had some slight splotches problems in my latest project that I never could get rid of, I am suspectiing now that my “store with irradience map” vraylights are the problems..
Will do testing to find out for sure…
