VRay Load Errors
So I get this error message when I launch Sketchup 2018 followed by a Bug Splat
If I uninstall VRay, Sketchup 2018 works fine,
also Sketchup 2017 works fine with VRay installed
vray_adv_36001_sketchup_win.exe
any ideas what could cause this
We are aware of this issue and our developers are currently working on implementing a solution for the upcoming hotfix update.
In the meantime, as a temporary workaround, you need to disable the Dynamic Components plugin.
You would need to uninstall V-Ray first and then start SketchUp. Access the Extension Manager (Window menu) and disable the Dynamic Components plugin.
Install V-Ray for SketchUp and then start SketchUp. The V-Ray plugin should load without any issues.
Could you please follow up on the email I sent earlier as well?
