Vray+Max backburner and saving lc+irr files
we ususlly net render files through backburner. The LC and IRR files are only saved if the file finishes the render. BUT if max crashes after the LC and IRR calculation is done, those files are not saved and we have to re-do the entire process
Is there any automatic way that the files get saved once that part of the calculation is done, besides saying “dont render final image”
using vray 1.47.03 and max 8 sp2
Vivek
there is a ‘save maps per frame’ check box under the indirect illumination panel.
hi,
thats always got a check mark on by default…still does not save lc and irr if it crashes during rendering, after they have been calculated.
Am i missing something here, or will Vray only save the IRR+LC on render completion and not on completion of that part of the render process.
Please educate me…
Vivek
have you got autosave checked and a file specified in the ‘on render end’ dialogue?
Yes..to both
Please understand that it saves the files if the render finishes, But will not save the IRR / LC if the render is interuppted by Bitmap filter error or any thing else, after the IRR and LC have been calculated.
I guess its something that i will have to live with
Vivek
