VRay MaxScript question ...
Hi guys,
I’m trying to write a script to automatically set certain VRay material values of all VRay mats in the scene, by entering one value in the script. But how do I avoid the script trying to set specific VRay material settings in native Max materials in the scene, causing an unknown property error?
Here’s my script so far:
MainFloater = NewRolloutFloater “Set VRay properties” 300 315
Rollout VRaymat_prop_refl_subd “VRay mat refl subdivs”
group “Refl subdivs value”
label enterreflsubdvalue “Enter refl subdivs value for all VRay mats in the scene”
    spinner reflsubdvalue align:#center range:[1,1000,15] type:#integer scale:1 fieldwidth:45
    button setreflsubdvalue “Set refl subdivs”
) -- close group
on setreflsubdvalue pressed do
        for i = 1 to sceneMaterials.count do
            sceneMaterials*.reflection_subdivs = reflsubdvalue.value*
) -- close rollout
AddRollout VRaymat_prop_refl_subd MainFloater
Thanks very much in advance for your help.
Cheers,
Metin
Got it figured out. The important part of the script now reads:
        for m in sceneMaterials do
            if classof m == VRayMtl then
                m.reflection_subdivs = reflsubdvalue.value
well, brute and slow method:
try sceneMaterials.reflection_subdivs = reflsubdvalue.value
catch()
better:
if sceneMaterials.reflection_subdivs != undefined then sceneMaterials.reflection_subdivs = reflsubdvalue.value
in case this doesn’t work:
if ((classOf sceneMaterials) == VrayMaterial) then sceneMaterials*.reflection_subdivs = reflsubdvalue.value*
something like that…i’m not sure if the classOf is really VrayMaterial, you have to try it out.
Thanks Plastic,
My method seems to work, so being a script sucker I guess I’ll leave it that way. :slight_smile:
Cheers,
Metin
yeah it’s the fastest way anyway…you just don’t really need all the brackets :wink:
:sweat_smile: :smile: But it looks like I’m a real programmer that way. :wink:
By the way, the first version of my script “The VRay automator” is finished. :slight_smile: You can find it here:
http://www.metinseven.com/menu\_goodies.htm
Spread the word and lemme know if you’ve got cool suggestions for the script.
Cheers,
Metin
