Vray Maya – Material override for proxies
Hi Guys,
Is there a way to get proxy shaders to work with a material override in maya “render setup” (image attached)?
I’m in archviz and now that I showed one client a “clay” render, I’m getting the request more often. My problem is, I have a base scene setup with many assets that are proxies (each with many shaders attached) but when I add them to the collection for material override, nothing happens they render with full textures.
At the moment I have to go though each proxy and manually change all the assigned textures on the proxy node with the clay shader. But some projects are large with 100s of different proxies so I cant do it that way.
Thanks for your time.
Kind Regards,
Mark.
Seems to work fine on a simple scene. Try refreshing by making the main layer visible and switching back to the override layer. If that doesn’t help, can you send a simplified version (one proxy) of the scene here? Also, which V-Ray version are you using?
Hrm yeah still having issues. I made a simple scene with just one proxy and packaged/uploaded to Submission ID# TYZ3-TLFC
Cant work out what’s going on, maybe I setup the proxy wrong or something. Thanks for taking a look at this. Cheers.
Thanks for the provided scene. Simply turn on the VRayProxy’s “Force Default Shader” and it should work. To make things easier when working with a lot of proxies, set up an override for that checkbox, too; this way you’ll control all proxies at once.
That works, thank you so much!
