Hi, i have a big issue with vray mesh export. When i try to export multiple object with option "export each selected object in a separate file " an error occurs : "there was an error creating the .vrmesh file for node [VUtils::subdivideMeshToFile] cannot create file.
Anyone can help? I can’t even export a single object with this option enabled…
A possible cause might be if the directory you’re exporting to doesn’t exist or is not accessible for some reason.
Is the export actually working fine if you switch the export from multiple to a single vrmesh file?
