Vray next 4.2.001, Crash of open vfr 2.x of rhino 5 file at Rhino 6 sr24 & rhino 7 Wip, why?
As topic.
Anyone have a same problem? Thank you!
Have Rhino crash is definitely not an acceptable behavior regardless of the version of V-Ray that was used to make the scene.
If you haven’t already, could you please send over the project file for investigation to support@chaosgroup.com ? You can do so by using the Rhino menu V-Ray > Pack Project and then share the archived file via a file-sharing service of your choice.
The following info would also be of great help in the investigation:
- your OS version
- list of 3rd-party plugins used in Rhino beside V-Ray
- when the crash occurs (at file opening / initializing render process / finish render process / etc)
- Rhino crash dump file
Kind regards,
Peter
There have a any update of this problem? The rhino crashed when I open all the old file with the invalid name of vray material?
My Vray is 4.2.002
Hi @pun1407
Could you please share the file with us so we can investigate in detail? If this is alright, please send an archived copy (V-Ray > Pack Project) via email or a file-sharing service to support@chaosgroup.com
