Vray next (also update2) + Hair and Fur multiple nodes/modifiers Bug
I'm having a quite annoying bug with the Hair and Fur modifier with Vray.
My object has 3 different hair and Fur modifiers on it, with each a polygon selection. All have a quite high count of hairs and multistrands.
The problem is that the hair and fur modifier on top doesn't render correctly. Lots of hair missing !
If I Move the modifier from place in the stack, the upper modifier Always renders buggy. See pics
Scanline render renders all of the hair.
I recreated the problem in a simplified scene with one sphere. Same problem.
Updated Vray to the update 2 but the problem persists
1trick is to make several instances of e.g. the sphere for each modifier, but I would prefer not too.
Anyone encountered the same issue?
spec:
max 2019, vray next update2 Same problem with max 2020
Hair modifiers on test scene :
1: hairs 300k
seg. 10
renderpasses 2
multistrand 8
2: hairs 500k
seg. 15 renderpasses 4
multistrand 10
3: hairs 500k
seg. 10 renderpasses 1
multistrand 2
![Bottom_bug.jpg|2146x921](upload://7THN3V2XA5fekLovOAFR5RZIzdi.jpeg) ![Middle_hairbug.jpg|2149x929](upload://pEjv3r1yEMmf89J6B4YitcDATYT.jpeg) ![top_hairbug.jpg|2160x944](upload://3ctJyMenAEYGYF4pry892yE8RU0.jpeg) ![head_hairbug.jpg|1961x1340](upload://q6bIEzmOV0ay7JeXRkdj8F6qEDa.jpeg) ![body_hairbug.jpg|1963x1260](upload://lhNIyjMCvRZEkYTmk938OfFI8r8.jpeg)
I will ask someone to try and reproduce this here.
Thanks, let me know !
Hello!
I tried to reproduce your issue but with no luck so far.
Could you please send us the simple scene for testing - the one that demonstrates the hairs distribution on a Sphere? It will help us a lot.
You can send it to me - margarita.stoeva@chaosgroup.com
Thank you!
Margarita
Thank you for your scene! I just tested it.
Unfortunately, I confirm I can reproduce the issue with it now. I’ll forward it to our developers to look into.
I’ll let you know if I can think of another workaround than the one you suggested.
Margarita
Ok super! I hope it can get fixed fairly rapidly. Thanx!
Hello Margarita,
Do you have perhaps any update on this?
Thank you
Hello!
I’m sorry to say that we have not developed a fix for this this yet.
Your issue is logged with number VMAX-8853 in our bug tracking system - feel free to use this reference.
I suspect the timing is no good for you because you mentioned that you hoped for a rapid fix. Until our developers get to this issue you may want to check the VRayFur or try Ornatrix in your scene?
Look into the VRayFur example I attach. I tried to make it look similar but further enhancements can be done.
Margarita
VRayFur_2019.zip (673 KB)
Hello Margarita,
Could you tell me where I can check the bug tracking system?
I Don’t think VrayFur would be suitable for my project. (Maybe for the test scene but not enough controls for an animal).
I know Ornatrix, but my workflow here is with Hair 'n fur. (no plugins, except vray of course :))
I used now the trick of having multiple meshes, but I can not work further with this method neither present it this way to my clients.
Thank anyhow of taking the effort of re-making the scene with VrayFur, but this was just the test scene to reproduce the bug.
Thanks!
Hello!
I’m sorry that the workaround didn’t help for your project. I hope you have managed to complete it in some other way.
About our bug tracking system - there is no public access to it. The issue number I shared was for making it easier to reference your case with the logged entry.
(And I can check and inform you that there’s no development progress on it yet.)
If you have the time, I would appreciate if you could share some experience on the features you miss the most in VRayFur.
I agree it’s not as powerful in shaping hairstyles as the plugins specialized for this exact purpose but probably some improvements may be considered if suggested.
Also, you may want to check out the VRayFur styler if you think it may be useful to you: Chaos Docs
Best regards
Margarita
Hello Margarita,
Can I still expect any fix for this? Or is it a lost cause?
Hello!
I apologise for the late reply (shame on me).
Unfortunately there is no fix developed for your case yet so I asked our devepolers to make time and look into it again.
Margarita
