Hi, if i am install vray next with 3ds max 2016, can i still have the vray physical camera? or i only can use the built in physical camera?
Yes, you can use Vray phys. camera with Vray Next for Max 2016.
why you vray next version difference then me? which one is lastest? where can download it?
This is a nightly version (not officially distributed, something like beta with code not fully tested so might have bugs). If you want to use such a version you must send an email to Chaos and ask for access. I would suggest that you use the official versions unless you need a specific bug fix that has just been implemented and is still not released in the official version. You can check and download the latest official version by logging into your account in www.chaosgroup.com
Thank you for explaination.
