I have tried batch rendering for different scene and files. But now it cannot batch render the different camera even I have set every batch rendering settings right!
It batch renders the viewport scene for the next coming renderings. Is it a bug or can anything solve this problem?
Thanks!
This works fine here, according to my tests. Which V-Ray Next/3ds Max version are you using exactly?
Figured it out! I have to switch my viewport to perspective everytime before I started the batch rendering. Otherwise, it will only batch render the same image from my Camera on viewport. Thanks!
Wow, thank you for tip, I was going crazy.
In any case there is something strange I can’t understand.
First of all, this problem happens just with 3dsmax 2018.
The 2016 version is ok.
Next problem is that, if you switch to a Perspective view before starting Batch render, it loses the white color balancing of the cameras.
I’ve tried launching a “net render” batch rendering and all is fine, it changes cameras and load the correct camera attributes.
It is a 3dsmax bug or Vray one?
Both 2016 and 2018 with Vray Next 1.1
Big thanks too. I was wondering, why sometimes I got always the same camera when rendering a batch, switching to perspective did the trick
Same problem exists in both Max 2019 and 2020 using Vray Next 2.1 GPU.
