Vray next dome light issue
Whwn i add a dome light to the scene, first it works well, but when i use transform and rotate it, it reacts as there is no dome light or hdr.. I solve the problem by rotating hdr inside dome light rotate horizantal..
Kindly note that we are unable to reproduce the issue. Could you please provide some additional information to help us resolve the issue?
1. Does this occur with specific project or any (even newly created ones)?
2. Please provide screenshots to illustrate the issue!
3. What render mode are you using? (CPU or GPU? Interactive, Progressive, Non-Progressive aka Buckets?)
4. Are you using any other 3rd party plugins?
Hi, of course i am using many plugins.. I couldn’t reproduce the issue, but, this time when i open the same file and hit render, dome geometry became too small.. I close and reopen the file and this time it became small when the file opens.. I create a new work file, add a dome light, render it, close and reopen it, it has no issue, working fine.. I am using cpu for renders..
Apologies for the late reply!
Could you please follow up on the private message I have sent you?
My vray next trial is finished, so i am back to vray 3.6..
