Too bad I have one workstation and one renderNode only…
You have 1 Workstation license package - https://www.chaosgroup.com/support/f…in-the-license . If you want to work with 3dsMax on 1 machine and send the rendering to another - you can un-check “Use local host” from “V-Ray interactive rederer DR settings”
No, I want to use all my gpus, including the workstation ones…
Just like with VRay cpu…
You need 1 render node license per each machine, so in that case you should obtain 1 more license for the second computer.
