Vray Next GPU: problem with triplanar mapping in bump slot
Trying to use a normal map with triplanar mapping, but regardless of how I wire it up it only works in VrayNext, but will not work in GPU. Known issue or just me?
I have tried bitmap>VrayNormalmap>TriplanarMap>bump slot, as well as bitmap->riplanar map>VrayNormal>bump slot. Nothing works, but the map will work fine if I wire it directly into the bump slot. It’s only with the triplanar map that it fails.
Thank you for the feedback. We have reproduced your issue and it is logged in our bug tracking system. As soon as we have any progress we will notify you.
Any news on this? It is quite an important feature…
We have increased the priority of the issue and will post here, when there is any update.
Any updates on this issue? Or any nightlies going on with it functioning?
