Vray Next GPU - Unhandled exception while updating VFB
“Unhandled exception happened while updating VFB”
This happened overnight when left rendering a scene, which did not complete and the crash happened apparently 15 mins after I left it.
It was caused most likely when the VFB was updating to the “effects result” element to show the Denoiser / Glare update. I have now unchecked HW acceleration on the Denoiser settings and turn glare off and will retry. FYI.
Running 4x1080tis.
First of all - when those errors happen we try to create a crash dump file called VRay.dmp located in your temp folder (%TEMP% in windows explorer). If there is such a file - could you attach it here or send it to our support ?
Also it would help if you could send the whole scene to our support.
Yavor
