vray next gpu
vray next stopped rendereing after calculating light cache.
It´s showing: prefiltering light cache in the lower status line of the frame buffer but it does not continue it does nor freeze i get this log:
any settings i messed up? The only thing i changed was noise 0,005 and light cache 2000sbdv
to be honest i can´t imagine being out of ram running a 32gb ram and nvidia p4000 8gb
The message says that you are running out of video ram (the 8gb on the p4000) - the next line shows some of the required memory for different elements of the scene. The total is close to 8gb and if the p4000 has display attached Windows and Max also reserve a portion - so it’s not impossible that you are running out of memory. Can you check your available video memory before starting the render and see how much you have ?
Yavor
Thank you for your answer.
How can I check my available memory? Question isn´t vray next gpu if I use it in combination with cpu designed to use my available memory of cpu instead whenever gpu is overpacked? sorry for the question but I don´t get that.
You can use 3rd part tool like MSI Afterburner, EVGA Precision or GPU-Z for that. On Windows 10 the Task Manager also has some GPU monitoring and there you can see the “Dedicated GPU Memory” graph (on the other hand - the gpu usage in the task manager seems not reliable).
You can use your CPU as another CUDA device but it is a separate device - the memory is not shared between the two.
4847,71 for mtls…Swiching the mode under textures to On-Demand Mip-Mapped might help.
Wow you`re a hero this really did work for me thanks =)
