Vray NEXT install lost connection to .mdl, and reflections now flashing.
All .mdl presets lost on VrayMdl materials in scenes, verified on Win10 laptop, Win 7 workstation, and render server.
System path is the same.
Also, scenes that rendered perfectly before upgrade now flash in reflections, with or with out GI, with or without new Dome light.
Would this have to do with the “locked” glossiness?.. the scenes has some “unlocked” materials from before, no longer supported.
This is veeeery strange. With what V-Ray version the scene was originally created?
Would it be possible to send us that scene along the .mdl files for investigation?
Lock/unlock glossiness is something completely different, it shouldn’t affect MDLmtl.
I think I have narrowed it down to the different paths to the .mdl’s on the three different systems.
The scenes were built with Vray 3.5
I will try “standardizing” the paths as much as possible and reset the max.ini and system paths.
Thank you,
Robert
Thanks for the update.
Let us know if you have troubles to make it work properly.
