i am writing this because i cant seem to be able to run spawner as a service.
In other words i need the spawner to work (be active or idle) even when i log out ow Windows.
Registering spawner as a service doesnt do a thing and when a DR job is ran, the node doesnt get picked up. I need to start the spawner manually.
Then whenever i log out, the spawner closes.
Any idea what i am doing wrong please?
Cheers
M
Which Windows version are you using?
Does it make a difference if you run the service with your account versus using a Local system account?
You can try in CMD
netstat -ano | findstr 20204
and see if you will see the service listening on the port. Normally it takes some time to start (a couple of minutes), depending on your machine
C:\Users\Ivan>netstat -ano | findstr 20204
TCP 0.0.0.0:20204 0.0.0.0:0 LISTENING 3128 (this is the PID)
