Vray Next Rendered Lines
I havent had this be an issue before. BF+LC leaving these lines. Doesn’t do it ever time and the lines dont appear in the same area every time. I am using the Vray Clipper so my hunch is thats what is causing this. Re-rendering the region will remove it.
I haven’t seen this before - would it be possible to send us some simplified version of the scene to support@chaosgroup.com so that we can check what’s going on?
Yes! I was having this issue too and reported it a few weeks back. I think turning my sun visibility off solved it for me.
I did a quick test and seemed like upping the AA time may have cleared it up but I will send Vlado a file
Might have something to do with the vrayclipper? Is that what I’m seeing?
It could be 100%. This is the first time I have used the Vray Clipper and the only time I have seen this so…
Is there any geometry matching those lines between the clipper and the camera? I think what’s been suggested before is to turn up the Max transp. levels in the Vray tab. Could be wrong.
No, no relationship and they float around in different parts of the scene.
