vRay Next rendering old vRay 3.X scenes differently
We are finding many scenes from vRay 3.X projects are rendering differently when we open them and render using vRay Next !
Looking at some of the threads it seems to be an issue with the Standard materials not being supported.
This is very dissappointing, ..will support for standard materials be added soon? (we really need to be able to replicate EXACTLY the output from old projects!)
As a temporary fix it would be good to have the option to select the old vRay 3.x in our list of available renderers, ..but this is not available.
Can vRay 3.x be reinstalled without interfering with the vRay Next instillation?
Also, if anyone know of some basic setting that can be set to help get our vRay Next renders to look like our old v3.X outputs, please let me know.
Regards
Jesper Pedersen
www.pedersenfocus.ie
Why anybody is still using standard materials, which are known to cause ANY kind of weird problem, is beyond me.
Hi Kosso,
Thanks for the helpful response. We’re a 3d visualisation studio and we get 3d models in from any number of different clients using different software packages, so it’s often convenient to just update the main materials and ignore perhaps 20 other Standard materials which perhaps are not directly visible in our views, ..so it’s not that we are applying Standard materials, but they often import like this from other non-3dsMax software.
Regards
Jesper Pedersen
Even if these materials are not directly visible, they might still cause errors. I remember we had a problem with some neon green GI spill, which as we found out was caused by multiple objects having standard materials assigned. None of these were visible in the scene, yet the error occured. There is a reason why V-Ray states this as a warning: “Standard materials and lights may shade incorrectly”.
If you don’t have the time to reassign V-Ray materials (a task which plays a big role in our dataprep), at least try to run the V-Ray scene converter.
In a scene with standard materials, I wouldn’t guarantee for anything…
Hi Kosso,
OK, thanks. I appreciate the tip!
Regards
Jesper Pedersen
Looks like an exposure thing. Can you adjust settings to get images to render the same? I understand the reason why us use the standard mats, but the due cause issues. Sometimes crashes, so we always wipe the out.
Mind that in 3.x there was a bug when you have Physical Exposure + exposure from a camera - they were mixed together. In Next, if you have camera exposure, it will be the only thing that affects the render (the exposure settings in the Env&Effects panel will be ignored when you look through the camera).
It indeed looks like Exposure, and @matanov explains why that is.
Standard materials, what @kosso_olli said: use the V-Ray scene converter (on the right-mouse menus), and you’ll be fine.
Particularly when merging stuff from varied sources, the scene converter offers the basic data-prep functionalities which will help avoiding issues down the line (although this isn’t what’s at play here, i’d wager.).
Hi Lele / Peter / Vincent,
Thanks for the help, yes, we’re coming to the same conclusion: We need to keep our vRay3.6 / 3dsMax2016 projects separate from all new projects which will be vRay Next on 3dsMax 2019 …problem solved for now, though I expect we’ll run into problems down the line!
Regards
Jesper Pedersen
Not necessarily: you’ll see exposure is one of the very few instances where there are noticeable differences (purely because the 3.x version wasn’t right. And it’s a very easy fix in Next.).
Next has been built with two things as main targets: compatibility with the 3.x line, and performance where compatibility wasn’t necessary.
You’ll come to love the Adaptive dome, and the myriad new features which will shave huge chunks off your rendertimes.
But you won’t need to turn them on to render a 3.x-authored file with next and obtain the same results of 3.x.
In fact, keep reporting anything which doesn’t behave as it should, if at all possible. :slight_smile:
