Vray Next (update 1) crashing with Forest Pro
Using Vray IPR or interactive rendering, max 2019 is crashing when manually moving or rotating Forest Pro items.
What is your Forest Pro version? Can you give me reproduce steps and a scene?
Hm it seems you’ll have to wait for a new FP version that officially works with Update 1.
Shitloads of crashes with FP on various occassions. As Slozer said this will most likely be on FP side
Man…don’t things get tested before they are released?
ipr does not support fp very well. Don’t expect to be painting trees in realtime. Additionally they informed me that 4.0.25 is the version that’s currently supported but I would not expect wonders from the ipr side. Gotta be reasonable.
Actually FP works well with IPR. And I will not get tired of saying the same thing on every release - 3rd party plugins should state that they explicitly have support for our new version. Using versions that are not compatible with each other is at your own risk.
Well, I reported an issue to them about painting / removing trees by paint brush while ipr was running which caused max unhandled exception and crash but they said it was one of those things that was not very well supported.
Funny…When Chaosgroup TV demos forest pack and IPR, it works fast and seamlessly. I know they are using GPU mode but it works. Now your telling me it doesn’t?
I have no problem with Forest Pack and latest VRay. IPR works fantastic with Forest in CPU mode. I had much more trouble in VRay 3.6 with constant crashing in IPR when FP was in scene. But in Vray 4 and 4.1 I have no problem so far.
CPU IPR is having problems in Update 1 and the last version of FP (which DOES NOT support Update 1 officially). GPU IPR is working in a different way and it should not be affected by this. Can you show me a ChaosGroup TV demo with FP and Update 1??
