afetr installed the vray_adv_61009_max2023_x64_32256, i cannot find the Diffuse path guiding option at Light Cache section
That nightly is not available anymore, however, the Path guiding is there in the most recent nightly (32258).
Hi, which version do you mean? the path guiding you mention here is “Diffuse path guiding option” or the normal path guiding only?
The label changed because now it does it for speculars and volumes too. ![]()
Yes, i didn’t recall the “Diffuse” path guiding option you mention either, but assumed you stumbled into some nightly with a misnomered label (as initially it only worked for GI paths.).
That one you see is the only path guiding option V-Ray has ever had, whatever its name may have been.
It mention in the nightlies release note 8) I install it because of the “diffuse path guiding”
V-Ray for 3ds Max (since 2023-09-05 build/32249 to 2023-09-12 build/32256)
No relevant changes
V-Ray for 3ds Max (since 2023-09-04 build/32247 to 2023-09-05 build/32249)
Modified features:
(*) V-Ray: Add an option for Diffuse path guiding in the Light Cache rollout; (VMAX-12953)​
aaaaaah, eheh, that’s the mystery explained! ![]()
Confirmed to be the one you screenshot! ![]()
