"vray Object Properties" Tag don't work
will it be possible in the future to make the “vray Object Properties” tag work?
thanks​
Are you talking about V-Ray for Cinema4D ?
Greetings,
Vladimir Nedev
yes sorry, Cinema 4d
Hi visualtracing__​, can you please provide more details on what specific function of the tag is not working? It would also be helpful if you could share screenshots or a video of the issue. Additionally, could you let us know what versions of V-Ray and Cinema 4D you are currently using?
Hi Zhanet,
I meant that if I have a scene with a background that I want to disable the shadows it casts, this doesn’t work. On vray work fine but on Vantage didn’t work
I use Cinema 4d 2024.5.1 with vray 6 update 2.3 and Vantage 2.5.2
Hi visualtracing__​, if you don’t want to cast shadows in Vantage, avoid using a dome light or sky in your scene. Instead, use the Background option in Vantage.
Hi Zhanet,
i’m work on live link and on interior scene is my priority work with dome light.
I understand the need for a dome light or sky. You can submit this as a feature request on our Ideas Portal.
