how do i get one object using the same material as the other to not show up in the reflections of just that one object? trying it here under vray object properties and can’t get it to work
Override material maybe?
funny thing is its not working for me, tried it both ways
ok so there is some change, in image one this how how the render looks and you can see the areas in blue where the problem is, the watch body is reflecting the band parts which i dont want, when i set all objects to exclude and not render this is what happends in image 2, basically little change and the area in red is now what shows up and help here@svetlozar.draganov
I wonder if the general section is too saturated with other questions
Would you be able to supply a cut down version of your scene so that we can take a look? It’s very difficult to judge whats going on by just looking at images.
Cheers.
sure will try to do so
ok all works fine now, seems it was my mistake, just reporting in, support responded and checked the files etc, so all is ok, i just missed some objects in the selection list i made which didnt exclude underlying objects
