Hi evrybody, do you know if i can use Vray on Autodesk Viz???
Thanks…
yes, I think you have to use the max6 build though.
-dave
No, you only use the Max 6 build if you have Viz 2005. If you have Viz4 than I think you use the Max 4 build.
But it works fine. I’ve been using it with Viz for almost a year now.
oops sorry my bad
I was thinking of Viz2005. Timmatron is correct.
-dave
Thanks to everybody…
