Vray on Mac python error
Mac M1
Houdini 19.5.640
Vray latest nightly for Arm64
Also I’ve noticed that the install puts vray_for_houdini.json not in /Users//Library/Preferences/houdini/19.5.
Also I’ve noticed there no installation help document available (in contrast to the Windows version).
Any advice?
Hey @vladislav_dunev ,
Indeed, we place the .json file in the Houdini installation folder as each build is made for a specific version of Houdini. The documents folder is shared for the entire major release. The documentation can be found here: Installation
As to the python modules issue at hand - it’s possible the issue is on our end. We’ll check and get back to you.
Best regards!
Hi @Gosho.Genchev ,
Indeed, we place the .json file in the Houdini installation folder as each build is made for a specific version of Houdini. The documents folder is shared for the entire major release. The documentation can be found here: V-Ray for Houdini
ah, in this case .json file location makes sense, thanks for the clarification.
And about the python - looking forward to your answer.
@Gosho.Genchev ,
were you able to find out something about the Python “module not found” problem?
While we’re at it, what is the proper uninstall and update procedure. There are 2 uninstall* files in vray installer folder.
I vaguely recall the support team mentioning there was a ticket open with them on your end, and the python problem being resolved - is this thread still valid, and should I look into it?
As to the uninstall process - we ship an executable under the V-Ray installation folder (by default): /Chaos Group/V-Ray/Houdini 19.5.435/uninstall
If simply updating to a more recent build, everything should be handled automatically by the installer.
Best regards!
