vray override material with sss broken?
Make a scene with a box and lights and apply an SSS shader in Pre-pass based illumination map mode.
Put a unchanged vray material in the vray override global switches.
Render still calculates pre pass even though it only renders the override resulting in longer rendertime for an identical image.
Vray 3.05.07
I mentioned this before, I don´t remember Vlados answer though…I do a lot of medical animations with mostly SSS mats, so it´s quite annoying…
We haven’t managed to fix this one unfortunately; will try to get it done for the next SP.
There is also raytraced sss - not sure how applicable it is your case, but it doesn’t require a prepass.
