Vray Phyiscal Camera Crashing Max Design 2010
Hey all. Searched the support forums to no avail.
I just upgraded to max 2010 and whenever I select a V-ray Physical camera and try to manipulate it in the viewport max crashes(happens in multiple files). I also have a new machine that I’m working on and have the latest performance drivers for the quadro series (my card is a FX3800). Anyone else having this issue? I may try to roll back to the regular quadro drivers but figured that I’d ask around here first.
Thanks much,
Dave
no problems here with VRay cam and max design 2010 wiht and old fx1500
about the driver, where did you find them?
as far as I know the performance driver are not available for max 2010, the dl page auto redirects to the standard graphic driver, 191.00
I got the drivers from Nvidia’s page. I rechecked and you are correct that they were the regular drivers.
I did however switch over to Open GL and the camera is no longer crashing Max.
We’re having similar issues (We all use Quadro 4600’s using the 191 Driver from Nvidia).
Crashing in DirectX mode but stable in OpenGL.
Currently trying to add any hotfixes above SP1, will let you know if that solves the issue.
Anyone else having problems?
