I am too new in the vray community and not so familiar with vray usage.
Currently i am trying to generate render to texture(vray complete map) for my scene with Vray Physical camera in scene but not getting similar light effect as per the actual physical camera render.
Does Vray physical camera support render to texture?
Or it can be done with license version only and not by the demo, as i am using demo version.
sitaram
It should work fine; just make sure you have selected to render through the physical camera in the Render Setup dialog (even though you are doing Render to Texture).
i am doing the same, but let me recheck.
However i want to add in my issue, that when i renders the preview window shows ok result but the final complete map has no light effect similar to preview.
sorry for my bad English.
