Vray plane
Hi only just noticed this is not supported. It’s very hard to hide the horizon line without it.
Have you tried using the sky horizon offset?
Hi rita_sobral,
If you need the V-Ray infinite plane just to hide the horizon line then Nikola’s suggestion should do the trick. Nevertheless I have logged in your request in our system under LAV-1481.
Alexander
Dray a plane and set the scale to 1000. Should help.
