When I right click now, the vray properties, proxy, and atc…are all gone…I still render fine, but something has happened…Anyone ever have this…
most likely you resetted your UI to a default one, or loaded some non-vray custom UI. All the VRay commands are available via the customize UI dialogues, so you can either re-add them manually or do a quick re-install. (no need to de-install as the installer auto-de-installs the old one).
Regards,
Thorsten
Had the same problem with one of my visualiser’s machines. Re-installed Max and all was well.
