Vray Properties in Max 8?
We are on a subscription license and have upgraded to MAX 8. Previously in Max, when you right click on an item, you get a flyout menu. At the bottom right were options for “Vray Properties” such as matte object options, and how much GI to recieve or emit. This menu option is no longer there, and I have not been able to figure out how to add it through the Customize User Interface screen. Anyone’s input would be greatly appreciated.
Did you install vray to max8? or just copy over the plugins… try a reinstall
One of the guys here at work had the same problem with Max 8 also. Not sure if he still does or not.
hi,
we’ve had the same problem,
you have to install a previous first, and then the .03.
i think it will work.
best greetings
What is this .18 version I keep hearing of?
