Vray proxies, materials and assignment files.
I just wanted to check, but looking at the docs, the issue where you have to create material assignment files, and link a vrscene to a proxy file using xml files…seems bizarrely complicated. I guess its for more complicated uses, where it comes into its own.
When i create a proxy, for example of a Tree mesh, I create the proxy, which has assigned materials in the maya scene…then export that proxy object as a maya file. So when i come to use it, i import that instead of using the vrayimport proxy option.
Then I just create instances of that in the scene etc…materials are already assigned, no need to create any xml files etc.
Does this way of doing it negate the point of a proxy in any way? Or am I missing something?
The functionality has a different purpose. The material assignment override is used for overriding particular shaders of objects in a VRayProxy (method varies between .vrmeshes and alembics) with ones, held in a .vrscene file. The .xml sets the rules, while the .vrscene holds the shader info. Check this thread’s discussion about the matter for more information.
