Vray Proxies
Hi all,
I have a problem with invisible to Camera Vray Proxies, which are casting Shadows, but don’t recieve such.
Here is the result.
http://img174.imageshack.us/img174/2158/ivisibletocamera.jpg
Where can be my mistake?
Thanks in advance!
I have noticed an issue where any double faces [even on internal faces] will show as black artifacts when ‘not visible to camera’ is checked.
wow gives me a dejavu.. i had the same “blackdirt” in a recent visualisation… but fixing the treegeommetrie could be a lil complicated..
I got same problem here. Is there anyway to solve this?
I’ve had the same problem. The only way I was able to solve it was to increase the Max. Transp. Levels in the Global Switches. I’ve had it up to 100 levels.
We’ve got the same problem.
Any solution?
Pleaseeee
Thanks.
Try increasing the “Max. transparency levels” option in the Global switches section. The default is 50, but you may need to go higher if you have many invisible objects one after another.
