I have allembic file come from Houdini, with path atributes, so model is organised by folders, and I want to assign to each folder, mesh their own material, and now when I assign it on folder only material from glass assigned to all model, even if on ropes is difrent material. May be the prbolem with Houdini inscatnces from Copy to Points?
Share the files (either here or via the contact form) so we can have a look.
Just sent a file via form
Thank you for the report. We found that if the same material ID is used in both objects, the material override workflow stops working. We were able to reproduce the issue in a simple scene.
We’ve logged this bug (VMAX-13326) and will share an update once we’ve made progress.
Please try setting the rope to a different ID that isn’t used by the droplet objects, and let us know if that helps.
Thanks!
Thanks for the quick response! I’ll test the suggested workaround.
In the meantime, could you clarify what the correct workflow is for setting up material IDs in Houdini so that they can be used reliably in 3ds Max? Currently, I’m separating meshes by partition attributes and naming them properly. However, with more complex Alembic structures (especially those with folder hierarchies), this approach doesn’t seem to work as expected.
Is it possible in 3ds Max to assign a Multi/Sub-Object material so that it’s applied to faces strictly based on their assigned IDs, rather than requiring continuous numbering? Since we’re using Houdini for modeling (architecture) and 3ds Max for rendering, having a clear and consistent workflow for material assignment would be very helpful.
I discovered another issue (duplicate it also here so user also can see the answers):: when an object in Houdini remains in the same position and is topologically identical, but has different partition attributes (used to create separate meshes and materials in 3ds Max), the exported result does not handle the material IDs correctly.
After assigning a Multi/Sub-Object material in 3ds Max, the meshes are visible, but they are not treated as separate meshes. As a result, the material IDs are applied incorrectly.
Expected behavior:
- Mesh _01 should receive material ID 01
- Mesh _02 → ID 02
- Mesh _03 → ID 03, and so on
Actual behavior:
- Mesh _01 gets ID 01 (correct)
- Mesh _02 gets ID 02 (correct)
- Mesh _03 is skipped, and mesh _04 is also skipped
- Mesh _05 incorrectly receives ID 03
This leads to skipped or misaligned material assignments.
