Vray Proxy and Vertex color
I’m having some issues with Vray proxies and Vray vertex color
I’ve some trees with Vray vertex color conected to control two shaders blend.
All seems to go fine until I convert the geometry to Vray Proxy.
The tree in the left is the original one, the trunk color varies from brown in the bottom to redish in the top
The model in the right is the proxy model, no color variation.
The leaves also doesn´t have any color variation in the proxy model
The Vray vertex color is in Set index mode and the channel set to 1 (otherwise it does not work)
Any solution??
Hi, thanks for posting. Could you upload the scene and assets here or using our support contact form. Please include a link to this tread in your e-mail.
Hi Vladimir, I’ll send you the scene using the support contact form
thankx!
Roberto
Thankx to the chaos support team, the problem was that I’ve not cheched the export vertex coolor option in the create V-Ray proxy window
Roberto
