Vray Proxy & material
I am using vray 3.7 and revit 2019.
After VRay Proxy is loaded, VRay material is applied to each ID-separated object.
I confirmed that the material corresponding to the leaves does not render properly.
The material of the leaves is the state that the opacity map is applied.
The original proxy file was taken from 3ds max, and the material was made from VRay material standalone.
Attached asset data.
I need advice on what I’m doing wrong.
Test Asset data : Dropbox
Thanks.
