I have a site file with about 1500 vray proxys (trees). I have this file xref’d into another file containing buildings and lights. If I render the image locally the vray proxys render fine, but if I send a net render they aren’t there.
I have configured my user paths in both files to ensure that the directories for the meshes are listed. I even tried placing a live proxy in the building file to give the path a kick start, but no such luck.
Is there something I am missing or do vray proxys have to be live to net render?
Re: Vray proxys in xref not showing up when net rendered
I’m not sure vray uses the use paths if it can’t find a proxy. Is the path for the proxy a UNC path (i.e., //server//folder/file) or is it a mapped drive (i.e., P:)? AFAIK, mapped drives can sometimes be a problem.
My apologies. I should always double check before posting. SOMEHOW the path to my vray mesh was mapped to a drive letter. I changed it to UNC and judging by the increase in render time I am assuming it is going to work now.
Thanks for your help and sorry for wasting your time
