I am looking for this pass, where can I find it in c4d/ corona?
[https://forum.corona-renderer.com/ [solved] raw light element ](https://forum.corona-renderer.com/ [solved] raw light element )
I did try that first but only found the diffuse, reflect, refract and translucency.
I need the light pass. Is it in corona?
I am not sure what you mean by the “light pass” can you give more details? The thread you linked to, the 3ds Max RawComponent was the solution, but it doesn’t have anything called a “light pass” either, so more information on what you are looking for would be needed (since the problem in the original thread was solved by this very same pass).
There are individual passes for Direct and Indirect lighting, in the Basic tab (but that was not what the original forum thread you linked to was about, so not sure it is what you’re looking for).
Hi Tom
I am looking for a direct light pass without any diffuse to the pass.
Please have a quick look at the sample the guy attached in the link or on the vray docs:
https://docs.chaosgroup.com/display/VRAY3MAX/Raw+Lighting+%7C+VRayRawLighting
the corona direct pass have diffuse included.
The Direct, then subtract the Diffuse version of the Raw pass in post? (as it would seem the answer from Marcin answered whatever the original poster was looking for)
