Hi, i would like to bake lightmaps. But if i use element RawTotalLightingMap i get also diffuse map in the render ( i should expect white diffuse for camera but diffuse map used pour color bleeding on white surfaces)
if i use a white material override, i lose the color bleeding effect in the rendered lightmap…
How can i deal with that to have white diffuse appearance and texture for color bleeding?
