Vray Refraction pass has reflection pass in it too - issue
Heya
I got little problem.
I’m using plane + shell + vray mtl with doubleside to get my glass going. But everytime I render refraction I get reflection pass included from interior of glass - secound bounce I believe.
Will this be fixed - or option added to disable it so I can have a pure refraction without reflection pass in it?
Thanks, bye.
Unfortunately what you ask is difficult to implement; you will have to find some other way around it for the time being - f.e. disabling the back-side reflections for the material or limiting the reflection depth.
All I had to change was a Refraction Channel from “All” to Collor+Alpha or just collor if I’m not wrong, and it render fine. Now the disadvantage of that is that I wont get light select passes/ID for those objects - which I find very helpful…
Do u think there would be a way to tick a button in Light Select pass to convert listed materials to channel : All, so I can get details inside my interiors and so on but not in reflections?
Thanks, bye.
