Hello, we have ordered Vray advanced and already installed. But, previous to this original version we tested with a floating on the web version
So now, when we install vray original and after delete all the old files in Max root and plugins, we do not obtain any reg dialog and renders have a lot of banding.
What can we do to use our Vray orig without artifacts in render?
You could try to erase this reg entry :
HKEY_CURRENT_USER\Software\ChaosGroup\VRay
then restart max and re-auth.
Thank you.
The reg code is valid only for one computer?
Sorry, I don’t have a clue about vray licencing.
But each time I had a problem, erasing this entry , then typing a valid auth info, solved the problem.
there is 1 work liscence. 10 DR liscences and unlimited network rendering liscences
