Vray Remap is bugged
Hello, it looks like when material/texture after remap node asks for a float texture, the remap node itself is working on “Value” mode no matter whats set in the UI. I’ll report this, but I’m not sure when this will be fixed, so for now as a workaround just add a “ColorToFloat” after the remap with HSV to use it as a float texture. Or use remap in “Value” mode.
HOU-1176 is the issue track number if you want to check our progress on it.
