VRAY Render Elements
I am sure I am just missing this but if you are using a Render Farm to render images, what setting do I use to automatically save the render elements as seperate files?
Hello @robusto92 ,
Is it a local farm (in your studio for exemple) ?
Or is it an online farm ? If so, it might really depend on your render farm type / spec / protocol.
I used to work with a Farm who didnt require any specific settings (other than the usual render elements setup in Vray).
Some of them might work with the “Separate render channel” (as in a local render)
The screen linked is from the GPU side but there is the same option on the CPU side.
Best,
Nicolas
