VRay Render Slave Issues
Hi guys,
Up and running with the latest stable VRay 2.10 build in Maya 2012, everything is great with the new versions so far other than my DR slaves hanging upon render completion/cancellation.
The frame will complete and then each machine just sits around for around 2 minutes until it finally returns the message “DR Session from 1.192.168.32 closed”. Normally in the past, I would see this message returned within an instant after the render.
If I try to launch a new distributed render, it won’t pick up until they close the session, which means I’m limited to rendering a frame once every 2 minutes.
Anyone else experienced this?
Which OS is this? Does it happen on any scene, or just a particular one?
This is in Win 7. I tried with a number of scenes, always seeing roughly a 1.5 to 2 minute delay between render completion/cancellation and the DR session closing.
This was magically resolved. Have a good feeling it’s to do with restarting the machines at some point since this build was installed.
Hm, ok. We could not really reproduce this here either.
