Good Morning All,
I am running into a issue. I have a piece of equipment that for the front controls I am using a image to display the buttons. I made this material inside Revit so when I render it with VRAY it turns it into a VRAY material like it should. The problem is that in Revit realistic view the image looks perfect, but when i render it the image shifts??
Screen shot of both attached
Hi kdickerson,
Do you mind sending us the Revit file along with the assets? We would like to test it in our environment.
Can you also point out your V-Ray for Revit version? (it is listed at the bottom of the About box)
Thank you in advance,
Ana
Unfortunately I legally can’t share the Revit file.
Revit VRAY Core version is 3.40.4; SDK 1.8.3; Revit 340.02
This version of V-Ray for Revit is outdated. Version 3.50.02 is available for download on our website. Here is a link to it: Download | My Chaos
Can you upgrade to it and confirm if the issue still persists?
Regarding the file, we can sign an NDA. Isolating the object along with the problematic map would also work for us. We simply need to test it in our environment in order to investigate what is causing the wrong mapping.
Best,
Ana
I will update and see if the problem persists. Regarding the scene, I can dummy the scene down and send. Will update you soon.
Ok, I’ll wait. Thank you!
Przekroczono maksymalną liczbę znak?w
1104/5000
Wpisz tekst lub adres witryny albo przetłumacz dokument.
Anuluj
PRZETŁUMACZ WIĘCEJ
The picture shows that the texture is shifted to the right and connected to the next one - that is, the textures in tiles, a checkerboard. As far as I know, the v-ray in the current edition can not be superimposed on the image object as it can be done in Revit - the Decal function. I tried to make the material with the texture application without duplication. The material was made in Revit and rendering using v-ray. Unfortunately. In rendering, the picture was moved to the right. In general, how to set the texture in a v-ray to its size, the dimension was what we expect. In Revit, in the material editor, as you click on the texture, a window appears in which you can set the sample size. How can this be done in a v-ray. For example, we have the figure of a man with a cut out background, we make the material with him in order to have the figure of this man in the picture (just like in RPC). We set the character height and render. In Revit, we see this figure of size as set, using v-ray, the person is smaller, lower. Someone may know how to do it using v-ray. I use the latest version of v-ray and Revit 2018.
Greetings, Marek
Hi all,
I’m unsuccessfully trying to reproduce the problem on V-Ray for Revit 3.50.02.
@Kdickerson, have you already upgraded your V-Ray version and what happened?
@Marek , do you have a sample scene illustrating this problem with Revit textures translation which you can sent to me?
Here are a few suggestions. Use V-Ray material.
1. The model pattern in Revit is connected to the V-Ray material pattern, so if you use a V-Ray material and want to adjust it according to object’s geometry, you need to go to any elevation or plan view in Revit, select a random line from the model pattern (by pressing the Tab button) and then move it. Note that this works for host elements like walls, floors, roofs etc.
2. In the V-Ray material editor, in the texture properties, there is a UVW expander where you can find settings for texture offset. This works analogically to Revit’s texture position.
Best,
Ana
The easiest way in Revit is to use the Graffiti (decal) function. When creating a texture material, they do not want to move. I set the texture of the banner without repeating it as a single one. The effect is visible in the attached pictures. With Revita rendering, the direction of the texture setting is consistent and in texture with the V-Ray the texture is rotated 180 degrees. Render from V-Ray Decal does not show up. How to do it?
@Marek_K , we don’t support decals yet.
@Ana_Lyubenova Finally was able to update. Still having the same issue. Still shifted. When i first created the material in revit for the image i had to shift and resize to adjust accordingly.
Please, isolate only the object + the assets in a separate Revit file and send it to us.
Will not let me attach a revit file to the forum
I know, that’s why there are private messages where I will explain you how to send us the file ; )
To access your private messages, go on top right corner of the page.
After analyzing the posts, I come to the conclusion that V-Ray for Revit can not render a single texture imposed on the material. Therefore, singular, that it is only once without duplication as for other materials. Applied once in Revit, he reverses. Without Postprocessing, it will be difficult to get the effect of, for example, a picture on a TV or poster on the wall. Poster for example of a single person. Sending an isolated file is pointless. It may not always be possible to send all the elements that should be attached (access paths). It may not work. That’s what I thought. Maybe the creator of the software will show on an example how to do it, how to set it to get the desired effect. If, according to these rules, it does not work for someone, then the error should be on the client’s side, not the software. The question is whether in V-Ray it is possible to apply a single texture to the material - an effect similar to Decal in Revit.
[/HR]
Greetings, Marek.
P.S. When can we expect a new version 3.60 V-Ray for Revit?
Any update @Ana_Lyubenova ?
Hi
Are there update on this issue? I would like to place a Decal in my scene. Is there a work around to place a picture in a scene?
Thanks, Niels
Hi Niels,
We still don’t support decals. Create a V-Ray material, assign it to a geometry and adjust the mapping from the Asset Browser (meaning the Sample Size Width & Height).
Ana
Hi.
Ana, and maybe some movie or description of how to do it with the assignment of texture without duplication on the object - the equivalent of Revit Decal. In revita straight, insert a picture and already - one cut. Here I have to do the material. The first post showed the problem. The problem was the material shift. I did the same - I made the material without duplicating the texture - only one. Vray did not take the exact texture - he moved in the bik and he came back. So something wrong. If yo is supposed to work in Vray, show me how to do it - it does not work for me, and I do not think I read other people’s posts either.
Regards
