I’m just starting to use Max 2022. when I right click in a view port none of the vray stuff I’m used to seeing appears in the pop up quad menus. Like vray scene convertor and vray properties. I can’t seem to get tht stuff to show up. suspect I may need to do something in Max preferences? Thanks in advance for any help.
Guess I should have searched on the internet first.
Here is a link to solution that worked for me.
There is also the little button in the vray icon tray that does this ![]()
MAX 2023 here and the button or the above does nothing; no quad menu
They moved a load of stuff out to the menu bar options with Vray 6, but you should be able to add it back if you want to, from customise ![]()
Fix doesn’t work for me and for some reason only a few of the vray-specific items I put into the quad manually stay after a restart.
What a pain to have to un-learn years of muscle-memory because menus get moved around…
Using max 2023. Not sure why but the quad menus are all there, unchanged and arranged as I had them in previous 2022 install.
