VRAY RT 3.0 freeze computer when trying to close the cmd window while rendering
Hello !
Happened 2 times this morning :
Rendering with RT GPU in activeshade mode, with netrender ON.
While rendering the activeshade, if i try to close the VrayRT cmd window (on main workstation), then the workstation freeze immediatly.
no other choise than manually reboot.
I don’t have made test with netrender OFF, as i’m a bit hurry and don’t want to kill my machine a third time :wink: lol.
Hope it helps.
btw : i do LOVE this RT 3.0 with render elements. Works fine in 4000-3000 with some render passes.
Still have some troubles when it uses maps and hdri (slave is not identical) but i guess it’s mainly a graphic card driver issue. I’ll check that.
Yes, we’ve noted this issue; it seems to be something about the video drivers, as this didn’t happen before. We’ll try to improve the close process, so that it is more graceful. It’s definitely not user-friendly if the machine freezes :slight_smile:
